3rd Annual MNTDR Dyno Day!
Bloomsdale,MO 4-wheeling - Late notice
RMTDR KDP Killin' Cookout - Oct/Nov 05
Jason... . There is a couple here in MN, PowerHouse Diesel..... They are at Hi-Tech quite a bit.
Also please let me know if he's gonna make it... . Right now I may have a few people come a little early to get a jump on it.
Josh
I'm still planning on coming as long as things go good this week, but I don't think I'll be spinning the rollers. I retorqued my head yesterday, so I finally got on it. It doesn't make much more boost at wot than at just over half throttle. Stays within range for temp without the box on, but when I turn it on, it'll wrap the gauge. Good news though, a ps 64 showed up at my shop today, I never even knew it was coming... but no downpipe, so I can't put it on yet.
Corey
Matt, I only have the one tire and wheel. It was the spare off my lifted suburban and was never run once. sounds like we can do some tradin to me.
Chris
Hey guys, i'm the friend of Matt's (Alphacowboy) that is planning on coming. I was going to install the Edge Comp and gauges, but I already got that done. We plan on installing a new VP44 now, I don't know how long the lift pump was dead before I installed the gauges (I actually think it was dead when I bought the truck). I put on a FASS fuel system to bypass the lift pump. I will have it ran on the dyno also.
JoshPeters said:
It starts at 10am... .
So I can add Jason, The Fat Kid and JMalliet to the list.....
Excellent!
Josh
Hot juice, maybe new tires ready to go :)
BTW, if I don't get new tires, traction is a problem on pavement. I can break things lose in 3th on a roll, 4th, depends, 50% of the time... . you think this may be a problem?
I don't think that will be a problem at all..... They only use 4,000lbs rollers.
They can and do strap these trucks down VERY tightly.
Josh
Josh I should be there 9:30-10ish, depends on when I meet up with with one the DTR members, Joe from WI that wants to follow me over. Sounds as if high is going to be 48-50*. Guess with temps like that changing out a VP won't be that bad, since the engine will be warm. Anything you need me to bring Josh?
Just you Jim!
If any of you guys that want to run on the Dyno can get here a little earlier, say 9. That would be great. I talked to the boys at Hi-tech last night and due to the number of trucks, they would like us to show up a little earlier. They are going to shoot for 3 trucks an hour.
Josh
So far between the TDR and DTR I'm counting 18 dyno runs... . Hopefully we don't brake thier dyno! This should be a GREAT turnout!
I'm looking forward to seeing you guys saturday!
Josh
Josh
hmmm I might wanna run more then 2 pulls. do they have the same basic rates to do more? I was thinking a stock base line, Edge on 5/5 and 5/4 and 5/3, maybe a 4/5 and 4/3... Some new information points to the fact that 5/5 isn't the best :)
Well this is a little off the subject, but over on the DTR site they started a map of members. I pm'ed to Josh and decided to create one for TDR members. Now I hope that I am not out of pocket copying anothers idea, I just thought it woould be a great idea.
TDR Member Map
well its closing in now better start swaping turbo's... ... ... ... . :D CSynder if you want to grab a burger and a beer i would love too but i work nights. after work i was going to swap a turbo out, but it will be past your bed time when i get home.
The Fat Kid
Andy
Well... . that you'll have to talk to them about. In the past... . as I recall it was $25 for 2 more pulls... . but you'd have to be last. You might be better off talking to them and getting a rate for something like that.
Josh
D@3n it!, Another chance missed! :{ Hopefully I'll catch the next time out, still in the process of moving from GB to Prescott.
Hey Josh,
Matt(alpha), his friend and I are going to try and get there early maybe 9:00 or 9:30. I just have to confirm this with Matt but it sounds like what he was planning on. Talk to you Saturday, I am curious what my new truck will put out for stock. I will try and bring a few pictures of my poor old truck. Makes me :{ when I see it in person.
Later
Randy
