This is not a blend door issue.
So I had the evac and recharge done today. They said that the system was nearly empty. Recharged, Started the truck and within 1 minute ran the AC on high. Popped the relief valve and dumped the system. He refilled the system and said good luck... kinda back to square one. On my way home I cycled the AC on the freeway after about 5 minutes of engine running and had cold air for about 20 minutes until I turned everything off.
Pretty clear the fan isn't coming on fast enough (or coming on at all) to keep the AC from extreme 450+ PSI excursions. One could ask of the AC shop what the high side was doing before the relief valve popped open (DUH!) I want to be nice, but, the *cough* shop is missing the #1 problem with AC systems and that be an INOP or weak fan. They sent you down the road with a system blowing the relief open with "Good Luck"?! To be fair: Did they suggest any repairs what-so-ever?
I would replace the fan clutch at this point. It's possible the high side AC sensor isn't reporting high pressure to the ECM. A weak fan clutch can keep the engine cool while the AC system burns up at around 190 degrees condenser temp. (190 degrees is around 430 PSIG and the relief opens around 450 PSIG, less than 200 degrees. 200 degrees = 488 PSIG.)
Need justification for the $500 fan clutch part? My experience suggests (as the Fan Clutch wait 15 min OEM test is a joke): Use a hand held optical tachometer or read the FAN RPM with a Smarty Touch or other tech tool. When the AC comes on you should have 1450+ fan RPM at idle before the high side goes over 400 PSIG. Any less RPM like 350 or 650 RPM is overheating the condenser and the head pressure rises till the safety relief vents. For this cost you should verify the AC pressure sensor is working via a scan tool. Gamble on the clutch part if you have an 5+ year old fan clutch.
To be fair, the tech did mention that I needed to replace the clutch fan... without any real discussion why. Ya, the truck is 13 years old on its original clutch, but my question lies, is the Napa replacement worth doing at the ballpark of $250 vs $500. I might as well replace the high side sensor while I'm at it. the system is already pretty low. Condenser is a little rough, some dents from rocks n such. What really throws me for a loop is that prior to having the system recharged, the fan was coming on at weird intervals, only this year. it would stop when I turned off the defrost or AC. I really hate throwing money at the wall and hoping some of it will stick.
Funny you mention this... so in the past week I vented more r134. Once after morning startup, even though I turned off the defrost. Then after driving literally all day, came up to a stop light and again started venting. I replaced the fan clutch yesterday (Napa special) cause I really didn’t want to spend $650 from the steelership and am leaving on a trip in a few days. The old fan clutch seemed a little loose to have less drag in comparison to the new one but nothing real obvious. I guess time will tell...I had same issue. A recharge of R134 helped but I had a tired fan clutch which showed itself only when towing heavy. Replaced with a mopar clutch. Passengers now comment on how cold it gets now.
Mine has been degraded for years now. Somebody at Dodge ought to have their carcass deep fried for building such a piece of excrement. This is one of those many components that could easily have been designed to last for as long as I own this truck.
