they make a 375hp version that is what banks started with for their sidewinder project!
Originally posted by Gonzo 1066
You can have a turbo diesel "run away" due to leaky turbo seals. Engine oil will burn quite nicely in your truck it just takes quite a bit of it. Check your new turbo end and radial play. Check the charge air pipes for engine oil.
Originally posted by JGoodwin
I agree. Most likely running on oil. Always keep a fire extinguisher handy in your truck. If it ever runs away spray it into the intake. Fire extinguishers are charged with co2. truck wont run with out o2. I learned that at cummins training.
Originally posted by SRadke
Halon is a good option for engine fires. Not safe to use in an enclosed space though.
-Scott
