nickleinonen said:i think there is something more needed to make the pto work. . on the IS controlled cummins engines at school with the pto enabled, there was 2 switches to make it work. one was a on/off switch that activated the pto function, the other was a momentary on/off/on switch that allowed you to control the engine speed for the pto. . so with that in mind, there is a minimum of 2 pins on the ecm needed, but most likely 3 pins are needed [on/off, up speed, down speed]. the dodge wiring schematics don't go into any detail on how the ecm needs to see the function![]()
Yes, you need one module for APPS and one for the Remote. The system we use is of our own design.
