Ok, so I had the same problem many of you had with the lamp out chime going off every 3 seconds when I go over bumps on the highway. I finally had to pull over and find an auto parts store and get some replacements. I looked in the manual and found the 2 different numbers and replaced the bulbs. The question is, the bulb numbers that are stamped on the tail lights in plastic read 3057 for all three and the manual says the 3057 bulb only goes in the middle spot. Which is right or does it matter. Can the lamp out chime be disabled by the dealer. Any help would be great. Thanks
Mark
Mark
