... maybe. Forget the electronics, I'm thinkin' hardware here Sportsfans.
This might NOT be doable, but bear with me for a minute because it MIGHT be doable. Given that some of us would like a mild timing option for towing and MPGs, I was wondering what it would take to move the cam sensor slightly. As I understand it, this sensor is examined at startup to initialize the injection timing and then is used only as a back up speed sensor to the crank sensor.
I think the way the crank sensor works (from reading the service manual) is that it has many teeth, but no TDC detection. The TDC detection comes from the cam sensor at startup. By looking at a diagram of the crank sensor wheel, it looks like it has 60 teeth. These teeth are looked at like an incremental encoder as they go past the Hall Effect sensor. With 60 teeth, that gives us a 6° increment.
The implication is that:
IF the crank sensor performs only as an incremental encoder and,
IF it is in fact counting in 6° increments,
THEN if we can find a way to either move the cam sensor the equivalent of 6° advanced, OR index the magnets on the back of the cam gear by 6° advanced, we might have a slick, code free, way to advance our timing by 6°!
This is likely to invlove some machine work on the rear timing cover. I'm NOT saying this would be easy or even possible, but there are enough sharp cookies out there to noodle on a possible solution.
Whaddya think??
100 Proof
Whaddya think??
100 Proof
