Originally posted by 100 Proof
Actually, if it works the way I think it does, you shouldn't have to touch the crank sensor, only move the cam sensor by 6°. I'm heading out for the 4th, but if I get some time next week, I'll try and R&R the cam sensor to explore the possibilities. This is not something where you can dial in any timing change you want. It would only be in 6° fixed increments because the teeth on the crank gear are 6° apart.
The way I think this works, the crank sensor is used for engine speed sensing and has no "home" or TDC measurement capacity. The cam sensor has the ability to find "home" or TDC. It has a magnet on the back of the cam gear that must pass past the sensor to generate that signal. This is why the electronic controlled engines seem to crank longer, that magnet MUST pass the sensor at TDC. According to what I've read in the service manual, this is ONLY looked at during start up, then the whole operation runs off of the incremental crank sensor signal.
I'd really like others to read the pertinent sections of the service manual to see if they agree with my assumptions of how this works or point out where I missed something. BTW, I don't know if 6° is too much. From what I know of gas engines, it's probably helpful. Someone else can weigh in on that.
Guys, I'm just exploring options here since the box solutions haven't been materializing.
100 Proof
