All that's been said here is true. One thing you should know is that it's not a simple drop it in and go. I had a #4 plate installed along with 370 injectors, new 62/14cm turbo and 4" exhaust. Yea, IT CAME ALIVE!!! Problem is that it also woke up the egts and the smoke level. Now comes the dial it in part. The fuel pump plate (fpp) can be moved a good 3/8" forward or back. Forward equals more fuel, and more smoke and more egts. Back is less. Then there is a star wheel adjustment that effects all of this too. It's a balancing act as to how much smoke (less mpg), ets (melts pistons), power vs economy, less egts (longer engine life) and less power. One more equation is the skinny peddle. You gotta keep your foot out of it to keep this undesirables under control. That vs needed power is what you do while driving it. The other is under the hood time. Try and retry until you have the balance you want. Some guys say they can make fpp changes in a matter of minutes. I can't disagree with them as I've only done mine once and the engine was cold. I can see the star wheel adjustment being a couple minute change, but not moving the fpp. This is only my opinion of course. I can see someone doing it fast and loosing bolts (screws) down inside the engine bay and things change drasticlly then. I think, to get the balance right you'll need some time and patients.
But then I'm only a novice at this diesel game, I've spent my whole life in gassers.
