4" Jardine Exhaust truly a Quality System
EGT Probes??????????
Transgo TFOD kit
Received my 4" Jardine Exhaust system yesterday. I installed it today in 2 hr. 15 min. by myself, and that included cutting 2" off the tail pipe and installing the 5" Monster Tip from Geno's. THIS SYSTEM BOLTED RIGHT ON!! I didn't have to modify anything, it is truly a "BOLT ON SYSTEM". And talk about sounding GOOD!! It sounds AWESOME!! THIS SYSTEM ROCKS!!
The only negitive was in the directions, after you install the muffler, the directions tell you to install the next section of pipe with the long end into the muffler (this puts the bend over the axle in the wrong place). #ad
That is wrong, the short end of the next tail pipe section goes into the muffler (at least on my truck). The bend over the axle then lined up over the axle. #ad
1500 to 3000 rpm runs with Power Edge before and after the 4" Jardine was installed.
-----------------without--------with 4"
Level #1---------11. 05----------10. 03
Level #2---------10. 12----------9. 59
Level #3---------9. 35-----------8. 57
Now I will have to admit that I was the one pushing the button on the stop watch. Vaughn (MacKenzie) I might need your help next time, I might of had a trigger finger. #ad
Except for the 1 flaw in the directions, it was a piece of cake to install. This is my experience with the 4" Jardine. I know that Larry Quinn had some problems. However it seem that Jardine has correct these problems per my experience. It's a GREAT PRODUCT AT A GREAT PRICE, AND WITH A LIFETIME WARRANTY to boot! #ad
"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's LSD, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (truly a bolt on system).
Things to come;
285/75R16 Cooper A/T's, Pyro,Boost and Fuel Pressure gauges.
NRA Life Member! (Need to protect our rights and FREEDOM!!)
[This message has been edited by BIG BOB (edited 09-29-2000). ]
Bigbob,
The numbers speak for themselves. It looks like you got a good power increase with the 4"
My Jardine exhaust was a major dissapointment. My problems and Larry`s were about the same. Maybe Jardine has something against Connecticut folks. I dunno
Glad to hear yours turned out well #ad
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7 º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno`s Exhaust Blanket,Espar Heater (won it!), Synthetic lubes throughout.
[This message has been edited by HEMI®Dart (edited 09-29-2000). ]
Big Bob this was my first group purchase item,the last time i talked to them, they decided to make it the g/p price their regular price now!!And after all they sold us they should have it right!!
