A good example of what I am talking about is the 27-5L made by Northwoods.
I own one ... before they re-imagined what numbers mean and made it wider and longer. Made of wood not the aluminum. On the grades it's heavy. Reach for the tuner heavy. Eventually back off due to reaching the limits of the cooling system on the 2003 I had heavy.
The couch, actually not too bad comfort vs. some others, was the first thing tossed out the door. Cloth recliners take it's place. Feet up is 1000 times better.
Slides will eventually make you pay for the space they give you.
I don't plan on going out when it is below freezing temps.
Yeah well good luck with that. The weather isn't exactly predictable, vacation time off requests may take longer than weather can be forecast, and you are either going weather be dammed or missing out.
Woke up at 20F and waited for it to warm up outside. Altitude and clear sky overnight cool things off fast! Just fine 74F inside. Pushed the button and made coffee on generator. I no longer run straight 30 oil in the generator due to cold snap surprises like that. It simply doesn't get below 32F here long enough to care, but, outside of "home" it does.
The A/C is another matter with a 13.5K BTU unit I am too cheap to replace with a 15K. 80F inside in 117F heat no shade isn't bad.
Fixed the A/C ducting to get that. Moved the power converter close to the AGM batteries to get the most out of Generator runtime limited by campground allowed hours. Like 2 hours in AM and 2 hours in PM. Use the AM gen time to bulk charge and solar to top off.
If I did it over I would do 50A service with two A/C units. 30A is limiting what I can run at once esp. with the A/C running. The converter power draw charging low batteries I forgot about and tripped the 30A breaker.
Like you I planned for it's main use for different weather aka "Get out of the heat." It's done some of that, but, had to make do in extreme heat more than I ever imagined.
Simply prepare for it say with heated insulated hoses and don't let weather decide if you can use it or not.
