As y-knot said, there is no adjustments for the rear axle, but it will tell you alot about any tracking problems, or abnormal wear in the rear tires.
I had my truck aligned, and re-aligned, then aligned again, and the truck still didn't have a centered steering wheel when going straight. Finally after plenty of frustration, I took it to another shop, he suggested a four wheel alignemt, and discovered a ball joint that was shot, and a bent rear axle,, to the tune of 2* toe in. The rear axle was making my truck "track" crooked and that's why, even though the front wheels were "to spec" the wheel was never straight.
THe technician used some huge calculator, and a litte bit of voodoo, and got the truck steering perfect.
A 4-wheel alignemnt is more of a diangostic's tool, than an adjustment.
If one side of your truck has a shorter wheel base than the other,, the truck will pull to the shorter side.
My $. 02
Merrick Cummings Jr
