Hey All:
There are options here!(options that are "tried tested and true" on the really rough stuff). There are 2 different 4 to 1 kits (that I know of) availiable for the NP 241HD, that will only affect LOW RANGE, leaving high range for flying down washes - whatever.
The other and absolute best option is to switch to an Atlas 2 Transfer case. It if FAR STRONGER than even the venerable NP 205, it is a gear driven unit (as oposed to our chain drive units), and the tourque capacity is WAY beyond an NP 205 and WAY, WAY beyond that of an NP 241. It is also cast of a far sronger material and the case is much stronger.
This unit (the Atlas 2), also gives you alot of options, such as; A 4. 3 to 1 crawl ratio in low range, Stock High range, 2 wheel drive low - and high and some other stuff not often used, but handy. You get 2 levers sticking out of the floor instea of our one, and yes, it will fit perdectly in the Dodge mounting position. The set-up has been used on Dodge Rams, Cummins powered too - just give Advanved Adapters a shout, they will set you up with every thing you need.
I can vouch for the quality of their products, as I am certain (IMO) some of the boys who run the radical, super-modified Jeeps who hang out on the TDR - Sam Houston, The "Scrambled guy"- (sorry I got your handle wrong, I just know you have a h@LL of a nice CJ 8) to mention but a couple. There are suprizingly many of the "big Dawgs" on the site, guys who have the rigs you see on T. V Rock Crawling events. Guys who I respect for thier knowledge on this subject (everything 4 wheel drive). Perhaps you should be talking to one of those guys, I am sure that they have forgotten more than I know about wheeling and build-up's.
I sure hope I have not offended any of those folks by mentioning names, as I sure could use thier advice and would like to be able to draw upon thier wealth of knowledge in the future, hint, hint
. If I have, I am very, very sorry. I was just trying to help folks out - the TDR.
I hope I have been of some help. I am just a rookie, but I guess I just happened to "wander" onto a tread I knew a little about.
Just my $1. 02 (I live in Canada - exchange rate).
The Cannuck
