Stock injectors? I think the 7" must add about 50hp. That's a lot of power. There is probably room to move up if your boost and egts are still safe. More diesel!!!
What level is the Smarty on?
Stock air box and stock lift pump? Did they just clean up your injectors for you? Don't they have a "stingy" dyno as well. I guess the proper setup and some good smarty software and voila 450 cool hp.
I could definitely use some more power. This '03 seems to pull as good as my '97 did. It has more horsepower but my '97 had as much torque. I'm going to try an intake horn, and maybe a different muffler and maybe a cool hose. i think I need 50 ft lbs or so to be where I want to be at. Maybe some economizer nozzles if I had a lot of coin to spend.
Gus do you use a boost elbow? I have one that I could try. If the smarty saw more boost would it give you more fuel? Maybe that would work best for me. I see 25 psi and 1100 F.
only 28 psi, 1100 degrees! hits 32 psi on the street.
thank you DDP!
my mods in signiture
Put the Aftermarket turbo software on it. I run 45-ish with the stock 04. 5 turbo. you could get away with close to 40 I'm sure...
What's the difference between the 4. 5 turbo and the '03? Would it be worth changing if I found a 4. 5 take-off for a good price (free)?
100 Proof
