I have an '01 2500, Automatic and a Edge Juice Chip.
The transmission slips (almost positive its the TC Lockup Clutch) when the Edge Performance chip is installed. It slips even when I am driving on flat land with no Load.
When the Chip is removed, the trans will not slip at all.
Now it seems obvious that it is the extra torque doing this, but without the chip, I can tow a 15,000 lb 30' trailer up steep inclines with no slippage at all, even in overdrive with the TC Locked.
With the chip installed, It slips even with light throttle on flat land with no load. The chip was checked out as OK.
I adjusted the TV Cable to make it tighter, now the trans is a little better, but shifts at a much higher RPM, and still slips a little in OD with TC LOCK (chip installed) If accelerator is floored during slippage, it makes it catch again.
Anyone have any idea how to fix this properly, or have any experience adjusting the transmission line pressure???
Any ideas would Help.
Mike
2001 Ram 2500 5. 9 ISB w/ New BOSCH Vp44 Injector Pump (supposedly upgraded)
2004 Fleetwood Gearbox 30 foot Trailer
2002 Fleetwood Slide in Camper
Edge Juice Performance Module
Mike
