wildmanben said:pretty easy really, just make sure you dont hurt the lip seals on the pistons going back together. An extra pair of hands is really handy doing this. Just pull it apart and put it back together the same way. Takes about 20 minutes.
JoshPeters said:I've seen the input shafts break 2 ways. One is the splines from the shaft to the drum walk up onto eachother splitting the drum and stripping the splines. The other can get ugly... actually breaking the shaft. If that happens you'll be sending your converter out to get cut open.
Depending on HOW the shaft broke... You could be needing a front pump, converter, etc.
I'll see if I can find some pictures for you so you have something to follow.
JP
