Ok I would appreciate any help that anyone can give me. I have a 95 dodge with newly rebuilt transmission with a Trans-go shift kit (Standard not race) and a Goerands Brothers triple disc converter. Today I blew one of the junk stock pushlock oil cooler lines out of the transmission, along with most of the transmission fluid. Instead of going through dodge and getting the upgraded fittings and lines, I can build them for half the cost at my hose shop. So here is what I need to know:
How do I use the resistor in place of the transmission temp sensor that is in the original cooler lines (it needs to work in cold temps)? I plan on not using it.
Also, I have to come to almost a complete stop for the transmission to kick down into first. I have adjusted to TV cable and it does not seem to tight, any ideas? Throttle control on the valve body?
Also, does anyone know if there is a bushing that the throttle spring rides on on the TPS housing? My spring slides all over the shaft and I don't believe it is supposed to? Also part number if anyone knows?
I appreciate any input!
Thanks,
Bill
Thanks,
Bill
