I've been noticing that when driving in Tow/Haul, the converter is shuttering on the 1-2 change, then again going into L/U 4th. Its been getting worse and worse. When going to the lake the other day, it slipped pretty good going into 4th, but hasn't done it again. Increased load DEFINITELY makes it worse. Another issue I've been having is the converter draining down when it sits for several days. It actually rolled back into the trailer yesterday when my wife was going to take it to town!!!!. The trans. itself does hunt a little at low speed/load conditions, but I just altered my driving style some and that doesn't happen anymore. The truck only has 29,000 miles, under warranty until October, and completely stock and always will be. With all that said, heres my question... .
If the dealership has to pull the converter, I am going to purchase an aftermarket converter to replace it with; I would really appreciate input from those of ya'll who have in the past or are currently running aftermarket converters. I want something that is a "drop-in" replacement, does NOT require different programming, and is built specifically for towing at stock power levels. Any input/suggestions are greatly appreciated.
Note: The dealership IS going to perform the update on the governor solenoids to correct the 1-2 hunt while its in next week and adjust the bands.
