48re has small leak
Boost elbow?
Turbo Air Guide
My transmission has a small leak. Small amounts of oil driping out if the little cover that is held on by 3 screws in front of the transmission pan. I took to dealer and they put dye in the fluid.
Any insight?
Will the dye cause any trouble?
bish
Are you seeing drip spots where you park overnight?
My transmission is oily on the front too, because the breather tube goes down the back of the engine and as I drive the air flow throws it against my transmission. I don't see any spots on my driveway so I know my transmission is not leaking. If you were to look under my truck it would look like the transmission was leaking from somewhere.
They are probably using dye to verify your transmission fluid isn't leaking. I'm surprised they didn't atleast explain their rational.
Make sure its not your block heater tube... I thought mine was transmission fluid but it was coolant... Our coolant looks very much so like trans fluid. .
Nick
No spots in the driveway. The only place the fluid is, is around that little plate on the front of the transmission. I took the plate off, three screws and was full of some kind of fluid under the plate.
Doesn't sound like my situation. Let us know what comes from the dye test and what the ultimate diagnosis is. Sounds like it is transmission fluid.
