Ok guys a little info on the new trans. . Scheduled to begin production in December. Higher capacity pump,increased line pressure in 3rd and odrive,lock up in 2nd above 220 degrees. Direct clutch in od unit has 23 disks with friction one side only. 5 disk frt clutch pac for std power 6 for Ho version. Higher ratio kick down band lever. OD carrier 6 pinion design. Thicker drive shell for heavy duty reverse operation using thrust bearings. Stronger park pawl. E brake compatible. Sounds like maybe they were listening to Bill
