Greetings TDR,
While changing the trans fluid on 05' 2500 4x4 100k with the intent of installing trans temp sender in the pan and adjusting the bands, I noticed a crack on what I am assuming to be the reverse/1st band? I took pics with a friends Iphone so I apologize for the quality, but I was trying to dodge any ATF from dripping on her phone. It is located towards the back of the pan and connected to something that opens a valve of somesort (I am an auto trans newbie). There is significant side to side play between the two cracked pieces.
Upon discovery I did not install my temp sender in the pan, or adjust the bands. The trans was rebuilt by dealer at around 47k miles on extended warranty (truck was stock) was better for 1 day then back to the same similar problem as before. Took it back to the dealer several times, but tech was never able to confirm customer complaint. I had just assumed that this is how the automatics are in these trucks, as this is my first diesel/automatic.
I have done searches, but it's hard to search when I'm not sure what I'm looking for. I did not overtorque the bands in 72ft lbs as opposed to inch pounds. The magnet had a nice full layer of fine material in the pan.
Is this the reverse/1st band that is broken?
Can it be replaced by pulling the valve body?
Should I get an upgraded valve body now and replace at time of repair? I had been debating an electric OD lockout compared to a valve body as I need od lockout but didn't want to lose Tow/Haul. I have been saving for a new trans for awhile now but still dont think I have enough for the one I want.
The truck is used occasionally for towing, and more often for hauling , but spends a majority of it's time with a light or no load. It is my daily driver, and only form of transportation short of a bicycle.
Any help is much appreciated, thankyou.
