48RE transmission issue
Torque Converter
No oil in filter at oil change?
MSkyrman
My truck with the original 48RE transmission now has 117,000 miles. I have the Edge Juice with Attitude and never run more than the 'tow' setting. For the past 4 years we have been fulltime RVing, so a fair amount of towing our heavy fifth wheel across the country back and forth. I have never had any service issues with the transmission... standard fluid and filter replacement, no adjustments to the bands to my knowledge. The last time I had the trans fluid replaced they did note it smelled a bit burnt and recommended a different transmission fluid which doesn't break down and burn at higher transmission temperatures.
The issue I'm experiencing is this. After I put the truck in reverse, then go to drive, it acts like its stuck in first gear and revs real high before shifting to second gear. By accident I discovered if I shifted from reverse into park, then to drive, everything worked normally. What gives? Is this a sign I need to have some adjustments made?
If you haven't done it yet replace the gov pressure solenoid and transducer before trouble shooting more. It could be a VB linkage issue or valving issue or the above sensors. If your fluid has had a burnt smell you might have somethig stuck in the solenoid that is causing the issue or the fluid change knocked it loose.
You should definitely have the bands adjusted next time you drop the pan for any reason. One band adjuster is inside the transmission and the other is on the outside. They're supposed to be adjusted every 30,000 miles when towing.
But your problem sounds like it could be the gearshift linkage is either loose or misadjusted. I believe there's a bushing in the linkage leading down to the transmission which can pop out or fail. Since this doesn't require dropping the pan, you might try it first.
Good luck,
John L.
Did you take their recommendation and put something other than ATF+4 in it? If you did that could be the cause of your new problems and I would recommend a complete flush. Also make sure the filter gets changed. BTW the ATF+4 is a synthetic long life fluid already.
The first time I changed my ATF it smelled burnt and looked discolored too and I was concerned, I later found out in the factory service manual this is normal and to be expected for ATF+4 and is not an indicator of any problems with the fluid.
As far as the bands go the most important one is the front band which is accessible form the outside, (it is a shifting band). The rear band isn't as important as is doesn't do any shifting, it only holds in reverse and manual low.
If your truck is an 03 or 04 you should probably have the TV (throttle valve) cable looked at and adjusted if needed.
I am going to disagree with that due to personal experience. I ran 40k and toasted the direct clutches with too much power, I mean REALLY toasted them to the point it ruind the input shaft. Slipped the TC clutch several times too many also and never had a burned smell, fluid never even lost the red tint. The only indication was excessive clutch material in the pan and fluid.
If ATF+4 is smelling burned and showing dark it got HOT too many times for some reason. It just doesn't do show that under normal use. Something is not holding the weight or power. If the trans is stock its probably multiple places slipping.
I will agree recommending something other than ATF+4 for heat is ridiculous. It handles heat better than just about anything out there aside from some tractor fluids.
As far as adjusting the band, the symptoms do not indicate that is needed. If there is flair shifting, loss of second gear, shuttle shifting, then maybe that would be an option but a band adjustment does NOT CURE ALL THE PROBLEMS. In addition, thats a really good way to make sure you need a rebuild sooner rather than later if is not done correctly, and, you cannot correctly adjust the flex bands for wear on the outside adjuster.
These bands are made for a one time adjustment and thats it. If it needs to be tightened down then there are other issues like the band stretching or excessive slipping that will not be fixed by an adjustment. This is not true if the OEM has been replaced with a rigid band.
The service manual clearly indicates regular band adjustments... every 30,000 miles for "most vehicles. "
Besides shifting problems, failure to regularily adjust the front (kickdown) band can cause it to become loose enough so that the link strut can fall out... just ask TDR member Dodoro: Front band wedge fell out -Reason for no 1 -2 shift
Best regards,
John L.
You can disagree all you want, I am quoting from the factory service manual and from what you're saying about the bands you're not qualified as a transmission expert.
I agree that his symptoms don't indicate a band adjustment problem but the OP stated he didn't know if it was ever done which is why I recommended it. A front band adjustment is very easy to do and should be done every 30k miles. All bands and clutches wear from normal use just like your brakes. You've got to be kidding if you think a rigid band can wear but a flex band wont.
I am well aware of the service manuals recomendations. I am also aware of who wrote that manual and the real world implications of following it. There is such a thing as "planned obsolesence" and looking at the factory band and the service manual it just kinda jumps out at one.
As for the band strut falling out, that was due to a misadjustment to start with, or the lock nut coming loose, or a failure in the band apply linkage. If all the pieces are in good shape, set correctly form the start, and locked correctly you can burn the band material off down to metal and the strut will still not fall out. There is not enough band material to allow that.
On my 05 I validated the band adjustment at 10k. It was almost perfect and still had plent of threads showing. I ran to 105k towing 10-15k frequently with power level up to 450 hp. I burned upo the direct clutch pack and when we tore it down the front band was perfect and well within the intital setting specs. Set it once every 100k and if everything else works correctly it doesn't need frequent adjustment. If it does it is a symptom of another problem.
Here is what the OEM band looks like. It has very little material to scrub off. If you have to adjust frequently it will be down to metal and eating the drum. I am not advocating never adjusting, just not using it as a cure for ANOTHER problem that will eventually trash the trans.
Never portrayed myself as an expert, and , yes I can disagree with the service manual in lots of instances. Particularly because I have burned up and spun the lining off enough bands to know what is going on with them. I have burned up enough clutch packs and had to track down the source to know a few things from a practical application stand point that is in direct conflict with said service manual. Its a "been there, done that" attitude. :D
Good bands and clutches are 200-300k, or more, wear item depending on use. Even cheaper ones like OEM are NOT a 30k wear item if things function correctly. If you want to believe that all I can say is the automotive repair industry needs your support. Talk to some high performance builders about where the issues are and the impact on wear patterns and how they are solved for high HP applications. It will give you a whole new perspective on the stock system and some of the service manual reccomendations.
Sit down with OEM flex band and an aftermarket rigid then tell me which one will take frequent adjustments and which one should not ever be touched after an intitial set. See my previous post for the why and quantifiable experiences. :)
I'm pretty sure it was Schaeffers All Trans Supreme, 204, something like that. The problem I am having did not coincide with this change in transmission fluid. I started having the problem before that by about 10,000 miles or so.
Should I take this to a transmission shop, or just a good diesel shop, to have it checked out?
Then you should do the governor pressure solenoid and transducer like Cerberusiam suggested or do that plus a recalibrated valve body from somebody like Suncoast or a shift kit with a through cleaning of the VB.
I am now getting a MIL with code P1740-Rationality Error detected in Tcc solenoid or OD solenoid... does this additional info change anything in your recommendations? No other symptoms with the transmission... just towed 1,500 miles from Mass to Florida. Is this repair work you mention above constitute a transmission "rebuild", or is that something more involved and more $$$?
I don't think either one of those items would cause the condition you explained in your original post (hanging in first gear). To answer your question, no changing a valve body or a shift kit is not anywhere close to rebuiding a trans, valve body work can be done with the transmission still in place.
It depends on what is causing the issue. Now the other 2 solenoids are showing issues that indicate they are not reacting like they should.
Your original problem has been cured by changing the gov solenoid. If you have not done that yet, its the first step. The P1740 could be the solenoids getting dirty, the wrong fluid, or possibly the TC going bad.
If you have been doing a lot of towing over the life of the trans it may be time to pull it apart and check things out. The diretc clutches and TC clutch are the weak points and once they start going its time to rebuild.
FYI, do NOT order just a VB. Find a competent builder and have your done. With too many of the VB swaps you are getting a modified 47RE VB because there are so many more of them available. While they work there are subtle nuances that throw gremlins into a 48RE system that make it har dif not impossible to resolve issues.
MSkyman,
You didn't provide any information in your first post or following posts so it is hard to offer anything other than generalized information.
What year is your truck? What is the weight of the trailer you pull? Do you have a transmission temperature gauge installed?
The 48RE is a good and durable transmission under normal usage but it has its limitations when pulling a heavy travel trailer full time. If you routinely force it to back a heavy fifth wheel trailer up a slight incline and have to stop, pull forward, adjust your line, and back again it will overheat the transmission fluid everytime.
If you routinely subject it to that kind of service, which is normal for trailer towing, the fluid will require much more frequent changing. The OEM ATF-4 is a very high quality synthetic ATF, the best that Dodge engineers could source for your transmission. Unscrupulous or uninformed service techs will occasionally attempt to increase their profit by convincing you to use something else. Don't follow their advice.
My advice would be to have a high performance heavy towing rebuild done by one of the well known transmission builders who are known to the membership.
My own preference is DTT (Diesel Transmission Technology), a British Columbia company and pioneer in that market. I had a 48RE built by one of their authorized transmission builders, James Northrum of Texas, build one for me using DTT components when I owned an '06 that was used for heavy, high mileage towing everyday of its life.
Other TDR members have other brand preferences so inform yourself and make your own selection. The main point you should understand is that you will need a heavy duty rebuild for the transmission to stand up indefinitely to heavy towing and you must use extreme care in selecting the components and builder who will do the job. An ordinary local automatic transmission rebuilder of unknown track record will take your money and disappoint you.
And install a transmisson fluid temp gauge and Mag-Hytec deep finned aluminum pan. Both are available from Geno's Garage.
I think I've got it, I believe your rear servo is the culprit, it gets applied in reverse and manual 1st. and is known to get cocked in it's bore. Normally the rear roller clutch holds in auto 1st. and if the servo got jammed from being in reverse it will hold first as if you selected manual low. I don't know why but somehow the pressure is being relieved when you go to park.
P1740-TCC O/D SOL PERFORMANCE
When Monitored:
The Torque Convertor Clutch (TCC) and Overdrive Clutch (O/D) will be tested each time the PCM requests TCC engagement in 3rd gear and O/D.​
Set Condition:
The code will set if the expected RPM drop is not achieved while attempting to engage TCC or O/D. This indicates a malfunctioning torque convertor or overdrive clutch.​
POSSIBLE CAUSES
CAMSHAFT DTC PRESENT
ENGINE RPM DTC PRESENT
FUEL LEVEL LOW
MISFIRE DTC PRESENT
OUTPUT SPEED DTC PRESENT
P1765 DTC PRESENT
PARK/NEUTRAL DTC PRESENT
PTO ENGAGED (IF EQUIPPED)
TORQUE CONVERTER CLUTCH DTC PRESENT
TPS DTC PRESENT
TRANSFER CASE IN LOW RANGE (IF EQUIPPED)
TRANSMISSION RELAY DTC PRESENT
TRANSMISSION TEMPERATURE TOO COLD
INTERMITTENT
CHECK TRANSMISSION FLUID-DEBRIS
CHECK TRANSMISSION FLUID-STALL
3-4 SHIFT SOLENOID
OIL PAN CONTAINS EXCESSIVE DEBRIS
SHAFT OR SEAL DAMAGE
TCC SOLENOID
TORQUE CONVERTER​
MSkyrman: The trouble shooting procedures for this DTC involve eliminating the various possible causes listed above one-by-one, and ultimately certain transmission components are replaced as needed... including the torque convertor. If you'd like a copy of the full diagnostic procedures, PM me your email address and I'll send you one (too large to post here).
Best regards,
John L.
You quoted me on this post but didn't indicate what work if any you had actually done. Are these symptoms in addition to the original post or new ones after doing some work?
These are symptoms in addition to the original post. I haven't had any work done yet.
