4bt transmission?
Which transmission and transfer case?
a conversion question
I have a 4bt in a old frito lay van that is paired with the TH400. I plan to put it in a 94 Dakota 4x4 and I'm wondering what would be the best manual transmission to switch to. Would a NV4500 bolt up or is there a chevy manual transmission that would bolt up to the gm adapter?
The NV 4500 is the manual transmission of choice and was used by both GM and Dodge in there diesel aplications. the adapter on the back of the block can be changed if the bell housing will not work with the your adapter.
