yep exactly about 65 at 1700-1800 rpms, about perfect...
driverswanted said:... Two layers of 30 lb. roof shingles were applied across both foot wells and over the transmission tunnel with one layer of roofing membrane between them. Two layers of roofing membrane were applied to the cab rear wall from floor to window...
driverswanted said:Andre,
My brother and I are looking at designing an MPG meter. It would have a programable LCD display along with differential flow sensors and take in pulses from some road speed source like speedometer pulse source or driveshaft rpm. This would allow anyone who has this installed to be able to adjust their pumps or driving habits for better fuel economy and see immediate results of those adjustments. Still looking for ecomonicaly priced turbine flowmeters. I consider this idea a tool to use in "final adjustments" so I'll keep posting any updates right here.
Picked up two more mpg by rotating tapered pin back to original factory setting (worn spot in center of pin in previous photo). Full load screw is still 1/4 turn in from factory setting. Done towing the boat for the year so I moved back the settings to a better fuel economy.
