Yes, emissions testing here in Ct has started again.
The exhaust size won't have anything to do with passing or not.
I easily passed the first time last year.
I also went thru with vssman and his 96 and he had no problem.
We both made some "detuning" adjustments before we got there.
I rotated my fuel pin to "dog" position. (VE pump)
vssman disconnected the boost line to his afc control.
I guess we figured better play it safe just in case.
We both went to a place in Bethlehem which was good for us as we work in Watertown (he no longer does). I made a few calls and chose this place because they said I could stand next to the truck while they did the test. The other places I went to took the truck into another remote area for the test. . only visable via a tv monitor... no sound.
Anyway this technician did not believe in really running the rpm up. He only ran mine up to about 1400 to get the readings.
vssman's had to go on the rollers, but it looked likeonly about 35 mph.
The tech said he had only seen one diesel fail... an old Mercedes that literally filled the garage with smoke.
All others had passed.
Hope this helps a little.
Jay
