Enough is Enough!!!!!!! This is a "Buy Back" truck. It was purchased by the first owner in Nov 2009, and turned-in for buy Back in Apr. 2010 due to this problem. It should have been fixed by Dodge before release, but was not because the problem cannot be duplicated at will. I have had the truck for 18 months and been to several dealerships, and currently have an open case with the Dodge Customer Service Center with no resolution so far. Thousands of dollars of warranty work have been expended because no one is trying to analyze the problem. I need help from someone who knows the electronic 4WD system inside and out, including the signals and paths to the shift motor. There have been many occurrances of this actuation, including going into 4WD without manual input, but I want the expert to dwell on this one only:
With the truck sitting overnight, and not touching it, unlockiing it with the key fob will sometimes cause the 4LO to actuate one time. It will not repeat on sebsequent key fob input.
Please message me for follow-up phone call. The truck description in the signature is accurate.
