Me too!
Big A -
I'm glad you started this topic because I was almost ready to believe I had imagined it. My 5'er is also around 9,500# loaded. I just got back from going out to Mt. Rushmore and back about 2,600 miles towing (3,100 miles total).
I had a real hard pull up about a 8% grade (I guess), and at the bottom I got behind granny. She was running about 30 in a 55 zone (no joke). I could see the hill coming and I wanted to get a run for it but she was in the way. When we finally started up the hill the road split into 3 lanes (2 up, 1 down) and I got to go around her.
Basically 4th gear had just enough power to pull this grade, going into 5th would've resulted into going back into 4th. So I left in in 4th, running about 2,400 - 2,500 rpm. Mine started making a slight thumping noise. I couldn't feel it in the shifter or anywhere, only hear it. It sounded just like a tire going flat, as it got a little louder. I was mighty worried since I was pulling a 5th wheel with a 2500. When I let off it went away. I got back in the throttle and the noise came back. I let off the throttle again and by that time I'd slowed down enough to need 3rd. I put it in 3rd and it did just fine, no noises in 3rd.
Later I used 4th on some other steep grades on slower speed 2 lane roads. Some times it did it, some times it didn't. Never did it when not pulling the 5'er though. 5th and 6th never had this problem either.
- JyRO
