2nd Gen Non-Engine/Transmission 4WD Low Front Disconnect Kit + Automatic
2nd Gen Non-Engine/Transmission '98 Brake - allen wrench size?
Engine/Transmission (1998.5 - 2002) RED-Black or Silver?
I considered Bob's kit also. But if the motor on the axle goes bad, the vacuum kit will not work. I don't know of any of these going bad on a Dodge, but have two friends that lost them on Jeeps. JC
Consider me the first... :rolleyes:
Vac leak was causing delayed CAD engagement = banging in front end. I ended up cracking the snap ring inside of the transfer case resulting in requiring a rebuild.
get the kit
I have the Pacbrake 2 low kit in my truck and it's is a HUGE difference. My trailer is triple axle 33' & 12,000lbs. and has to be backed over a curb and into a fairly tight spot. I just put the truck into 4 low and then flip the switch in the cab (which is labeled and lights up when engaged) and the front diff dis-engages. The kit comes with everything needed including a lit switch and solenoid and vacuum manifold. The maneuverability and control is worth every penny of the quality kit. :cool:
I think I bought it at Piers:
http://piersdiesel.com/DodgeUSPrice.htm
PDR5718056 2 Low Diff Switch Kit $85. 00
