4WD vs 2WD?
  • Thread starter Thread starter NStates
  • Start Date Start Date
heater core
Euro? CTD
N
NStates
Guest
I presently tow a fifth wheel that requires a duel wheel RAM 3500. I am downsizing the fifth wheel to one that I can tow with single rear wheels. I then plan to sell my present truck and purchase a new RAM 3500 single wheel, and would like some input on 4WD vs 2WD for towing.
Would a 4WD make a better tow rig over a 2WD? Living in Florida I have very few times that I really need a 4WD due to road conditions.
:rolleyes:
No! They don't handel as well towing,less towing capacity,more moving parts,less fuel mileage,sits up higher. If you don't need a 4x4 don't get one.
I considered a 2WD very seriously when I bought my current truck. All the ones before this one have been 4WD. I finally decided to get the 4WD "just in case". Now, I wish I'd gotten the 2WD as I just don't need 4WD here. 4WD sure is nice for towing in Colorado in the colder months though.
I've owned a 3/4-ton 4X4 (gas), a 1-ton crewcab dual-wheel 4X2 (gas) and my current '03 3500 QC SRW 4X2 (see sig). After having the 4X4 10 years I knew I didn't need another one; after having the dual-wheel truck about 13 years I knew I didn't need another one of those either.
I've towed heavy loads with all of them; in the past 10 months I towed a 16' dbl-axle enclosed cargo trailer about 11,000 miles. Maximum trailer weight has been about 10,000 lbs; I've had tongue weights as high as around 1,400 lbs. It has been, in a word, easy. Better mileage with an SRW vs a DRW (less rolling resistance) and although I've seen comments about less sway and better control with a DRW, I have not experienced sway and have always felt the whole rig was completely under control -- and this has included steep down-grades, heavy winds and heavy traffic/truck congestion. With the addition of a wind deflector I've managed to get the fuel mileage up to between 13. 5 and 14. 3 MPG, depending on terrain.
I'd have NO hesitation of using an SRW, if I was in your situation.
Ditto, Though it is good to have the low range when backing the trailer if you with a manual transmission better than slipping the clutch
Backing up with low range is the only thing I miss about not getting a 4x4. Otherwise, I carry triple A (AAA) insurance, to get me out of the few pickles I get into each year. Much cheaper than 4x4. Plus I am not dragging all the extra weight around that I seldom use.
The only reason I thought I would regret me selling my '03 Hemi 2500 4x4 was our annual trip to Pismo Beach. It turned out to be nothing, as all I had to do was drop the air pressure in all 8 tires to 12 psi (truck and trailer) and I was able to go into the soft sand, while towing my 6500 lb trailer!! Here's a pic of me at the camp site. #ad
