2nd Gen Non-Engine/Transmission 4X4 Extension Hub Nut Torque
Engine/Transmission (1998.5 - 2002) Has Anyone Ever Figured this out ?
StevenWalker
I'm preparing to replace my stock rotors on my 2001 3500 4x4 with cryo Power Slots. The whole process looks simple. I have found all the torque values that I will need in my factory manual except for the nuts that hold the extension hub on. I'm guessing that the torque value in 145 ft. lbs. like the wheel nuts. Is this correct? Thanks in advance.
I've been working with mine a lot lately, I don't see how you can get a torque wrench in there. I use two 15/16" wrenches. One on the nut and one to add length to the first wrench. Tighten it down good and tight and leave 'em alone. They won't come off. Let me know if you find a way to use a torque wrench in there.
There's a knowledgeable young man in your Albe, N. M. area named Josh. Great guy to know. Hint.
