Originally posted by dan_gilson
I have a '98. The only way I could figure out how to do this with the book was to pull the hub. Dodge tends not to use any assembly lube for installation so it can be a real pain. Using the proper puller and a 15" cresent on the puller (or worse an impact). The hub comes right off. You then have to drive the studs off to separate the rotor.
Maybe someone else knows a short cut.
I found that getting the hub off was the easy thing. It was getting it back on that was hard. The threads on the axle are not out there far enough to start the hub and then thread it on. The only way I could get things started was to hammer it back in using a piece of wood to soften the blows. This was not something I wanted to do.
ALSO, MAKE SURE that you have enough threads showing when you started to thread on the hub nut. I did not and ended up cross threading the nut. It was ~$20. I also had to chase the axle threads. Lets just say it was not a god day.
I don't know what the job is for but if you are just turning the rotors, have them turned on the truck. It can be done and the job comes out much better for much cheaper!
I was replacing rotors so I did not have a choice.
