My '06 3500 dually 4x4 has a bad problem, need help diagnosing. Have searched threads and haven't found my symptoms. Stock truck and stock wheels and tires, 244,xxx miles. Just bought it last winter, no history known.
Suddenly while braking and turning a corner the steering required great effort, the brakes were pulsing, and the power steer pump began to whine. Drove the truck home slowly and it was all I could do to turn the wheel while the truck was moving , no power assist at all. In fact, it was much worse than what manual steering should be.
With the front wheels off of the ground and the engine off the steering feels perfect from lock to lock. Wheels off the ground and engine running the wheels turn but there are two or three areas of slight resistance. Wheels on the ground, absolutely cannot turn the wheels at all and the brake pedal pulses when pushed. If I rev the engine a bit and try to turn the wheels the power steer pump starts whining.
Help?!
Godspeed,
Trent
Help?!
Godspeed,
Trent
