My 1991 4x4 is ready for the expected steering shaft replacement. What I have is a good deal of slop in the steering wheel. I have inspected the tie rods and the rest of the front end and it is in good shape. The problem lies in the bottom joint of the steering shaft. Right where it goes into the steering gear box, there is some kind of square looking joint that has seen it's better days. I can grab the shaft and move it around inside of the joint. I hear there is a company that sells a kit to replace this joint with a sturdier unit. Anybody experienced this problem and what was the solution? Also, after spending about 15 minutes looking at the rascal, I can't figure out how that sucker comes out of there. There are no bolts to unbolt or anything. Do I need some kind of divine intervention or what? What is the procedure for removing this?
Thanks,
Pat Daniels
1991 4x4
Thanks,
Pat Daniels
1991 4x4
