Here is what the service manual states.
Lubricant leaking from output shaft seal or vent.
1- Transfer case over filled - drain lubricant to the correct level.
2- Vent closed or restricted - Clear or replace vent as necessary. (does not show where this vent is located?)
3- Output shaft seals damaged or installed incorrectly - Replace seal.
When your laying under your truck looking towards the front of the truck at the transfer case, you will see the ID tag on the transfer case. the bolt under the ID tag is the fill plug. The bolt below that and to the left is the drain plug. The fluid used in the transfer case is Mopar Dexron III, or ATF+3, type 7176. Correct fluid fill level for the transfer case is to the bottom edge of the fill plug hole. Make sure that the truck is level when checking the fill level. Tighten fill plug back at 30-40 ft. lbs.
I would suggest that you check the ATF level in the transfer case and if it is over filled you will know it when you open the plug. If it is low then I would think you need a new seal. I would top it off and drive it (keep an eye on it) then take it into the dealer for the warranty repair after the holliday.
Good luck.
