Originally posted by laketex
Studded tires are what??? and when do you use them?? Don't you guys run chains? Btw, I never understood chains very well, if you run them all winter or take them on and off all the time or what. Also, I guess i need to find my block heater and get a screen right?
Studded snow tires get put on in the fall, and taken off in the spring. Buy yourself two extra wheels to mount them on, then you can just swap 'em in your driveway.
Chains are a lifesaver with 2WD. Combined with weight in the back, you can plow your way thru most anything.
Chains go on at the beginning of the trip in the storm and come off at the end of the trip/storm.
The block heater and winterfront will help to keep the heat up, in order to keep the windshield from freezing up.
Last--get yourself some winter wiper blades--they are completely wrapped in rubber and won't fill up with packed snow like regular wipers, and stop wiping the windshield clear, until you crawl out and bang them clean for about 5 minutes.
You can survive winters with 2WD, you just got to get prepared for it.
