5.9L injectors question.
No boost or very low
The Cummins doesn’t do free revving well. It only runs well in the higher RPMs under load. Totally different from a gasser.
I agree. I was having some vibration issues a couple of weeks ago (turned out to be a rear u-joint), but in playing around with ideas in my over-complicating things head, I noticed this issue.
I have no idea what I currently have in my truck as I only bought it in March. I’ve assumed it’s stock, but it runs really strong, and will get up and go and smoke if you get on it. Runs up to about 3000 and shifts if you drive it that way. I plan on a Smarty Jr, but no tuner yet, unless it’s had something programmed in.
Wild guess is you have a tune on it already.
Because, no matter what I do to my truck - with the factory tune there isn't even haze from the pipe. Changes when I program the Smarty tunes.
A guy I work with has a 05 he bought new that’s stock, he can make it smoke where in never could with my 05. So it is possible, but I don’t think it’s common. The HPCR’s run pretty clean in stock form.
It will lay down a cloud of black smoke if I really get on it. Not as much as my stock 03 would do with the van Aaken box turned up. But it’s definitely more than a haze. I’ve seen no smoke or haze with normal driving.
I get 30 psi of boost. New air filter.
Me too, top end was fine. Problem was only the spool time in my case.
Just a slight delay there has a big impact on smoke if the boost build lags behind what the ECM expects to see at any given moment during this time.
But I said, more likely your truck has a tune already.
