I guess it really hasn't been "fixed" then has it?
After they get the truck off the lift and out the door make sure it is parked on level ground. Remove the fill plug on the axle and check the level of the oil and compare that to the specification in the owner's manual. I believe you will find that they are overfilling the axle which will make the pinion seal leak. For penance make the service manager crawl under your truck (no creeper allowed!) and check the oil level himself and then show him the spec in the owner's manual. Then have him remove enough oil so the proper level is achieved. While he is doing so go on a sane rant about how his incompetence has cost you a lot of head scratching and aggravation. Then drive away and your problem should be solved. If the seal still leaks you need to find a different shop. Perhaps a TDR member could suggest a reliable axle specialty shop in south Florida.
Godspeed,
Trent
Godspeed,
Trent
