I have a gear grinding noise that started last night after a 3 mi.
drive home from work. I stoped at a friends and let it idle for 15
to 20 min. Then turning up my street slowly shifted into 2nd
went 50 yrds. Then into my drive slow, put it in 1st to idle in
garage, had a sound like one of those rice rockets, stopped put
clutch in and whine slowly went away, hit reverse same noise,
back and forth this way a few times. Seemed to go away when clutch was released and in netural. I have had the transfer shifter
lightly bunged because of the rattle for some time. took the bunge off. Went out this morning for work and drove to work the normal routine, no noise at all. Not bomed, no heavey towing,
no hot rodding. 97 slt cc stock HP. 104K.
could use some input. first time on forum.
Drove home form work last night no noise at all pulled in driveway
left it in 2nd gear luged a bit then the gear grinding noise. No noise on the way to work???? Noise goes away slow with clutch in and in gear, goes away fast in nuetral clutch disengaged.
Gary.
Gary.
