I have a 5 speed in my truck with 180,000 on it. The last few monthes it has been jumping out of 5th gear when decelerating only. Yesterday I pulled the transmission to do a clutch job and popped the rear and top cover from the cast housing. Inside I found that someone had previously done the 5th gear update(I bought the truck with 80k last May 04) and it was still tight. Everything inside looks good yet and rolls smooth and the syncros look good yet. Upon further inspection I found the lower gear below 5th gear had a piece of one tooth missing but I was unable to locate anything in the old fluid or the bottom of the case. Has anyone here dealt with a similar situation and found a fix for it jumping out of gear? TIA, Chris
