Engine/Transmission (1994 - 1998) 5 speed transmission fluid?
  • Thread starter Thread starter DPellegrin
  • Start Date Start Date
D
DPellegrin
Guest
Hey guys I have to change the transmission fluid in my truck and I was wondering what kind of fluid to use. I got underneath the truck and it says use Castrol Syntorque only is this true or can I use something else? What is the best fluid to use? Thanks Nick.
Is there a write up on how much fluid is needed also the proper drain + fill procedures? Newb here, (truck 1 day old, to me anyways :-laf ) Hey moose, nice to see another guy from CT... Thanks. Jim
Slight hijack
Signal73, check out this site; They have tons of Dodge truck stuff, gas and Cummins,
http://dodgeram.org/
On the TDR site there is the Coffee night link; A bunch of the local Cummins heads hang out there online and the Occasional Friday night in Derby;
https://www.turbodieselregister.com/forums/showthread.php?t=119987
and this was last years,
https://www.turbodieselregister.com/forums/showthread.php?t=88580&highlight=Coffee+night
This thread will now be returned back to the NV4500...
Id like to stick with the castrol syntorque. Anybody know where I can get that stuff in Minnesota. Also how much do I need I saw one site said 8. 5 quats another said 4. 5 thanks.
The cheapest and easiest place I found to get the Syntorq is a GM dealer. Same stuff.
I just went to the new Amsoil MTG last night. Maybe a little too early to tell but it seems to shift better than the Syntorq. Also lost a little annoying "whine". Mine took 4 quarts.
If you don't have one, make sure to pick up one of those little oil pumps. I got mine to put lower unit lube in my outboard but it's just the trick to get the new lube in the transmission with no mess.
Scott
Like BigPapa said go to a GM dealer. My local Dodge dealer wanted $20 a quart the GM dealer was $12. I believe the quantity is 4. 5 quarts. I'm thinking of going with Redline next change.
I just finished changing my NV4500 oil today. I sucked most of it out through the fill plug then I took off the driver's side PTO cover to let the rest drain out. There was a bit of grey sludge on the magnet on the PTO cover but no big chunks. I cleaned the old silicone gasket off the PTO cover and put a new bead on and bolted it back on. I refilled with 2 quarts of Redline MTL and 2 quarts of Redline MT90. I had a little bit left over so 4 quarts should be plenty for most changes.
I went for a drive when I was done and it shifts better than the old stock fluid. The 5th gear rattle is gone also. Does it shift better than new Syntorque? I can't remember what it felt when it was new but I'm happy with the improvement over the old oil with 60000 miles on it.
Why did I use Redline? I heard some good reports and it was 1/3 the price compared to the local Dodge *******.
My old trans oil was very black? I'm glad I changed it.
Use Redline MT-90
TrqMonster said:
Where can you pick up some of that Redline fluid. I need to change mine.
I got it from Summit Racing. I used a 50/50 blend of MT90 and MTL, That is what the Tech. Rep. from Redline recommended.
I just disassembled my GM NV4500 transmission along with a Dodge trans. for my conversion. The Redline fluid looked like new. I will definitely use it for my conversion.
hey guys bought the stuff from the dodge dealership it was 15 dollars a quart o well cost me 60 bucks thanks for the help
