Engine/Transmission (1994 - 1998) 5" vs 4" exhaust
2nd Gen Non-Engine/Transmission Glove box fell off!
Ive read alot of threads on here about the exhaust systems and comparisons and from what Ive read there can be a loss of low end torque with a 5" system
my question is at what point is the 5" exhaust beneficial over the 4"
I have a 97 reg cab, stick, 215 pump etc...
bone stock right now
There should be no loss of power/Tq on a turbo diesel engine by upsizing the exhaust. You want the exhaut gasses to be able to have the least amount of restriction leaving the turbo, expext lower EGT's as a result. A 4" on you rig will do the job very well, a 5" would be over kill unless you are looking for a deeper sound.
SR
i have (had) a 5inch. i would not do it again. it looks good but ther is no need for it. i goes from 3inch to 5inch if you have a factory turbo and 4inch to 5 inch if you have a aftermarket one. also the spare tire did not fit with the 5 inch either.
i should have mentioned i run 33. 5 inch tires. sorry.
Vaughn is correct if you have stock size tires you should be fine.
