50 Liter Cummins!!!!!!
Looking For A 2004.5 Maint Manual.
Freightliner FL 70 W/40' G/N Trailer (E-bay)
Also check out the :
http://www.everytime.cummins.com/every/news/release45.jsp
The QSK50 is also available with uptime increasing options of CENTINEL™ and ELIMINATOR™. The CENTINEL™ Advanced Engine Oil Management System enables operators to extend oil change intervals to as much as 4,000 hours. The ELIMINATOR oil filtration system eliminates the need to replace and dispose of used oil filters and decreases lube system maintenance costs by as much as 90%.
Now, how can we fit that under the hood? Just a little modification, and she will drop right in, just needs a different oil pan.
How about the QSK78? 3500 hp @ 1900 RPM, 10150 ft-lb @ 1500 RPM. 78 liters. 4 turbos.
A QSK50 on steroids. :eek:
-Ryan :)
-Ryan :)
With a oil capacity of 304 quarts, that would be one expensive oil change.
that'd be cheap compared to the engines i work on... they are 200-300 imp. gallons lube oil capacity [so 1000-1500 quarts]
