Engine/Transmission (1998.5 - 2002) 53 block poll
who has or had a 53 block
  • own a 53 block
    Votes: 7 70.0%
  • had a 53 block crack
    Votes: 3 30.0%
  • Total voters
    10
Engine/Transmission (1998.5 - 2002) D70 Snagle Tooth
Engine/Transmission (1998.5 - 2002) slow needle
Had one in my former 2001. Owned the truck for 7 years. Highly modded. Probably over 300 passes on the drag strip and many dyno pulls and no crack. From what I understand, it is still alive and well with the current owner.
2 of my friends had modded '99's. One cracked, one didn't.
Had one in my 98.5 at 175K. Broke internally and was not fixable. Found a recycled engine at a recycler for $1800. There are lots of 53 blocks at the recyclers. It is a crap shoot on these 53s. they might run for ever and then not. I don't think it has anythihng to do with how you drive it or maintain it. If you have one you have a time bomb on your hands. It is sad that Cummins got away with it.
DClark
Anybody ever have one welded? I don't have a crack but my luck is not good would have never bought the pos if I had known it was a 53 asked the guy if it was he said it wasn't . Looked below the injection pump where I thought it was didn't see 53 thought I got lucky
I bought a 97 engine for a swap into a Ferd for a co worker several years back. The block was a 53 so we used another block instead. Didn't want to take a chance and we had another block anyway. David
My dad's 99 work truck with over 400k got a crack around 250k, had engine pulled out and JB welded it and no problems with it afterwards. My old truck was a 99 w the 53 and current owner is running over 600 hp and have not heard of any issues with it. I don't know what the block is in my 01
if it does crack probably going to lock stitch it . unless somebody will weld it in the truck had a combine engine welded in the machine once
If I remember right some one on here had that done and it did not last. The area in question is just to thin.
Dave
