555 Juice update from the President of Edge!
3rd gen camshafts- are they all the same?
engine oil drain time
I run the edge fuel rail psi increase on level 4 with great results, I want a timing module to piggyback on it. . Ca. lo output makes 300 hp with standard edge module. .
Come back folks, Thanks Marty
XcumminsX said:
If there is somethin better than edge out there with no problems someone please pm me and tell me what i can stack with my edge ez. My trans is 100% no worries but i havent added anything to the motor...
Im looking for something to add 120 - 160 hp that is safe and wont pop up 389792 codes...
I run bullydogs downloader on the 130 hp setting, with a TST on 2x2 setting, and a 85 hp pressure box on top of all that. I think bullydog has the code issue worked out now. I occassionaly get some codes but my engine runs excellent with all three stacked. I'd est. my hp at 500, and tq at 1000. Maybe more. Stock turbo. My '03 555 dynoed 413 hp and 835 tq and my 600 with the above stack feels alot more powerful.
I love bullydogs downloader, just plug it in for a few minutes and your done. Best throttle response of any box that I've tested. I do think that TST will dyno more torque though, so on the freeway with the transmission locked it will accelerate faster w/ a TST. I would definately say get the downloader either from bullydog, or quadzilla I think they may even be the same just different packaging. Quad says theirs is better though. You can stack that with your edge too, no prob. There's a 200 hp downloader available for the 600's, so I'm sure it will be avail. for the 555's here pretty soon.
We do not sell a tuner any longer. We used the same hardware as Bullydog with different software.
We do have something in the 120-160hp range, but it won't stack with the EZ. I would try the TST I guess? Some people have had decent luck stacking with the VA duration box, but the HP-$$$ ratio is a little high.
Hope that helps.
Quad
hehehe. I was kinda sandbagging ya'll -- I got the call as well this afternoon
BUT only 100hp?
I hope it can even spool my SP66
JStieger said:
Soooo... I read "somewhere" today :-laf ... duration, timing, and pressure...
All I gotta say about the Hot Version is that they better bring it!
Cause its gonna take quite a single box to de-throne the TST/EZ
MY BUDDY WAS CALLED TO TEST THE HOT JUICE IN MID JULY AS HE IS RUNNING TWINS AND 5'' EXHAUST FROM LOWER TURBO BACK... . Oo.
