A good chunk of that $2500 is labor to change the cam and lifters--a big job in the Cummins. See my article on the dowel pin and the page of pictures in TDR#33 for some idea what is involved. Another thing that adds a lot of cost is the purchase of a NEW marine cam, gear, bolt, plate, key, and set of lifters from Cummins. Only the special alloy (seems to be much higher in nickel and/or chromium) used in the marine cam has given us the best results on regrinding. Then there is the cost of the regrind and prorating the cost of development including a new master camshaft to be used by the cam grinder. The marine cam is the way to go because the gear is pressed on and bolted on also, so it won't walk off at high rpm. Furthermore, the cam core is ground and shot peened behind #1 journal so it won't crack off at higher rpm.
Now that you know it isn't cheap, feel free to contact me if you are still interested
Yep the cam ain't small block chubby, the chubby technology sure don't cross over, and the labor involved is way different. Just drop one lifter down into the oil pan, ruin another day, and then tell me how easy cam changes are.
Find that the couple lifters in the very back
of the engine won't pull up into their bores, your back is sore, and you are sick of the whole thing--then tell me the installation is easy and should be cheap.
Is it cost effective? Well, it sure ain't torque plate pricing, power gains aren't huge, but ask the drag racers--when you want to win, and you want the best, you do what you gotta do. If we didn't have to pay Cummins their "competitive"
prices for the parts to begin with, the end product wouldn't be so high.
