Landing Gear Noise
I just went through the same problem I called Atwood and they said to leave it to experts. I called my RV dealer and he said just relace them when they get too bad, as they would soon break.
I have a HickHiker Premier and have the "heavy duty jack option". This means 2 motors and 8000# lift each. Plenty tough, but very noisy at times. The noise was only when lowering the front of the RV.
I removed the noisy, drivers side, jack and tore it down. Found a spring that looks like a slinky toy over a cup that fits over the top and I guess only bearing. When I removed the cup, I found it very dry and rubbing on the outter race of the bearing. I washed the bearing and repacked it with axle grease and filled the cup with the same grease and reinstalled everything coating it all with white grease. All noise gone.
The Attwood guy said the spring, slinky was a brake and if too much grease was put on the threads, etc, the gear might come down by itself. I have seen nothing like this happen. Just sounds like it did new.
Not a fun job, but doable.
Good Luck,
J. V.
