My Scary Experience
I finally checked into this thread and figured I would add my story. I have been running with a deck on the back of my trucks for many years and have a fifth wheel plate similar to a big rig, but it is a bit smaller. (It is good for 30,000 lbs but have never been close to that. ) I have had this hitch for over 10 years and know the odd time the jaws have not closed properly when I pull away and the pin has dropped onto the deck and left its usual embarassing evidence. This would happen on my farm yard. My livestock trailer and grain trailer have sturdy jacks and as some of you do, my routine is to pull ahead while the jack is down. If jaws did not latch I would know. This particular time I had purchased a 3 ton load of feed from a dealer in a near by city, unhooked the trailer to do some other business and came back to hook up and go home. I did my usual pull ahead and visual check of the handle when I lifted the jack, plugged in the lights/brakes and hooked the brakeaway. I drove 1/2 block made a right turn, another block and left turn when I heard this awful sound of the pin sliding on the steel deck and off. I was in the middle of an intersection and was trying to crank up the the jack while some traffic was driving by. A commercial trailer business was at the corner and some kind soul came out with a forklift and helped me out.
I have thought about this incident on many occassions, and still don't know what I missed. I am just so thankful that this happened at less then 5 mph and not at a higher speed. After this accident I had a welding shop put a heavy bar on the ramp part of the fifth wheel that I can slide in and latch. THIS WILL NOT HAPPEN AGAIN!!!
This happened when I had a 91 Chev 3500, 454, 4 speed trans, with 3. 73 rear end. I would like to blame it on the truck but alas I have to blame myself.
Stan
