Has anyone had any experience with Amsoils diesel 5w-30? I am trying to decide if I should switch to the 5w-30 for the winter, or stick with the 15-40. I live in the Kansas City area. Any thoughts or ideas would be greatly appreciated. Thank you.
Buffalo said:A guy in my neighborhood with a new Powerstroke 6. 0 just burned up his engine with 10w/30. He took it in to the dealer for an oil change and that's what they put in it (verified by 2 oil samples). He had an Edge Juice with Attitude and no muffler. Was towing his toyhauler uphill at about 80mph and it started making a lot of noise and would only do 65mph. Took it into the same dealer, they pulled and partially disassembled the engine and said it would not be covered by warranty. He had it towed home and rebuilt it. Got it going, last night. Sounds good, now. Truck only had 5000 miles on it. I'd be careful about using other than recommended oil weights. Hope this helps. Joe F. (Buffalo)
lschultz said:You can run it if you want. I don't think you will see that much of a difference at least my son did not but we are down in Texas. He run the 5w30 for over 140000 in summer and winter. Only reason he switched cause the 15w40 is a little cheaper. I think there are quite a few fellows that live where it stays cold longer than around here that switch between the two.
PBerry said:Mobil 1 would also be a good syn choice as they sell their base stock to amsoil.
LightmanE300 said:Actually no, Amsoil buys their base oils from Mobil, and Lubrizol makes their additive package.
