6.7 class action lawsuit?
Sprint Booster Throttle Enhancement
Block Heater vs Driveway Pitch ?
I read the legal questionaire and i am in the the majority for the moment and dont have any of the issues to list and all my gripes have been fixed by the dealer so the truck is a good one ,but that was what i thought when the first cel came on too.
The in tank emulsifier pump does concern me though and some extra filtering would be great if it will pull water from suspension.
all is well with the AS flash
Austin Diesel
WELL if every one worked the truck like it was meant to be they would not be so much crying go on. The people that took the truck and worked it had no trouble with it!! Then there is cowboys that add all the extra horse powder then use it as a day driver and short runs. This does not let it clean it self!! Then all they want to do is cray and say it is the truck!!
Is the diesel pump fuel emuilsified as it passes through the above ground pump rotors ?
it is foaming or aerated as it leaves the pump nozzle unless it is above ground gravity feed tank like at the farm?
As i look at the filter canisters at the fuel station, discharge filter outlet fitting it is downstream and emulsified also coming into the onroad truck fuel tank from the pump discharge nozzle.
Are in line fuel station filters only about filtering particulate matter i do see that they have a water drain petcock on the bottom but how often are they drained ?
Pump filter sticker service intervals are not displayed well or ledgible due to canister fuel leakage onto sticker or discoloration or both,
reading fuel station fuel filter stickers more often now
Wif fuel sensor fault codes or equipment interaction analysis could be improved to protect fuel system injection component integrity
Austin Diesel
