#6 piston hotter than 1-5
Truck missing @ idle and low RPMs
Coolant Leak
Is the EGT out of #6 piston always about 100 degrees F hotter than the outher five pistons? I took a look at mine with an IR gun and at idle 1-5 were about 270 - 290 F and #6 (closest to the firewall was about 380 F. This all normal??
I saw another post about the melted #6 piston where someone mentioned #6 runs hotter due to the restricted exhaust gas path and less inlet air. If that's the case, you'd think a slight modification in the air distribution and exhaust gas manafold would make this engine a little more efficient (and less prone to melting #6)
The two piece ATS exhaust manifold should help. But the biggest problem is the intake side which has the smallest air passage to the #6 cylinder as of now there is no fix because it is part of the heads design.
When you shoot the manifold with a ir gun you are reading the temp of the outside of the manifold. The air flow cools the outside and the front will be cooler. The exhaust gasses will be hotter.
There was an article several years ago about putting the Banks Twin Ram on a 12-valve and comparing EGTs on the dyno for every cylinder before and after. The Twin Ram did balance out EGTs considerably, even though the 12-valve in the test didn't have a dramatic range between coolest & warmest. Seems like before it was 75F and after it was 25-30F.
I think the HPCR motor could benefit from a Twin Ram. The ATS exh. manifold is a big improvement, since it directly passes exhaust to the turbo inlet. I think anyone in competition should seriously consider one.
Another problem at #6 is the cooling system. Someone posted that the coolant tends to stall out there and not carry heat away as well. There is some sort of retrofit available on other B-series engines where the rear freeze plug is knocked out and a fitting & hose added to carry the coolant away more readily and balance the cooling at #6. Anyone remember where that thread was?
Vaughn
Not an engineer but I read some of the same things listed above. That's why I mounted my EGT probe in the 5/6 web (see reader's gallery). The highest temp I've seen, while towing my 32' fifth wheel, was about 1250 degrees. This is a totally stock truck...
It just boggles my mind why anybody would design an engine with an obvious problem like this. Of course, it's not REALLY a problem for a totally stock truck, but why not design it so all 6 pistons get an equal amount of air, exhaust back pressure, and coolant?
