Now here again you really ought to talk to him yourself... .
He said that the 180 injectors are plenty to handle that amount of fuel and the EGT's will increase about 100 degrees over the #8 plate. But they are still very manageable and in fact if you drive a truck with the #5 the same as a truck with a #8 you shouldn't notice a difference. But who wants to do that? Of course you'll need to remind me to control myself... . more power... . good... more power... .
I asked him specifically about my particular driving habits and current modifications such as the air filter and the lack of the cat.
TST has told me that through their extensive testing they found at our desired HP increases that the stock air filter was fine and actually may be preferable to the K&N, BHAF, etc... . Specially ported heads and exhaust manifolds had no appretiable benefit at our power levels and that the main problem was the cat. Muffler and exhaust diameter also didn't seem to change EGT's. If the temperatures get too hot for your tastes, then he recommended the 16cm turbo housing, but not before trying the #5 for a period of time. He thought the stock housing would be fine up to that level. The 16cm housing is non wastegated and kills you in the first couple of feet off the line but makes up for it on the higher end once pressure is obtained.
Remember, I claim no knowledge of any of this and contacted Piers, TST, DIS, etc... to obtain what little I do know and recommend you do the same... .
